configure radius algorithm
configure radius algorithm [standard | round-robin]
Description
This command is used to configure the algorithm used to determine the rotation of RADIUS servers.
Syntax Description
standard Standard Extreme retransmission algorithm.
round-robin Simple Round Robin retransmission algorithm.
Default
Standard.
Usage Guidelines
Use this command to configure the algorithm to determine rotation of RADIUS servers.
This command was first available in ExtremeXOS 16.1.
Platform Availability
